Handlebar out of alignment? Help?
Old Oct 9, 2010 | 03:32 AM
KongBastard's Avatar
If the frame isn't bent... a lot of times if you loosen the pinch bolts on the triple trees and the axle bolts and then tighten them back up things will go back into alignment.
KongBastard
Old Oct 10, 2010 | 12:57 AM
thrasher572's Avatar
When the bike got dropped did a bar end hit the ground? If the bar ends have scratches on them chances are the the handle bar is bent. Its easy to tell, at steering lock if your finger is getting pinched its bent. I bent one in 1988 when I lowsided in the foothills close to Deadmans Flats.
Old Oct 14, 2010 | 05:29 PM
tds94probe's Avatar
look at your triple tree, is that cockeyed as well?
Old Apr 4, 2011 | 09:42 PM
DomesDKG's Avatar
I have the exact same problem on my bike. Had a friend look at it, and he things that things got pushed out of the alignment when the bike was dropped by a previous owner. Same suggestion as above, loosen the bolts, have a buddy hold the wheel while you crank on the bars, and it should straighten out. I haven't had a chance to try it yet, but he had the same problem on a different bike and said it worked wonders.
Old Apr 5, 2011 | 06:50 PM
ski-line900's Avatar
I have had the same problem. There is a nice how-to wheel alignment thread if you search for it. Try to align the wheels and line it up with the handlebars, should straighten out. Can twist the handlebars if you loosen the bolts like you would on a bicycle as well.
Poblete
Jul 6, 2011 05:15 AM
CeeBeeAre600
Jan 14, 2010 04:42 PM
kevdiggity
Mar 30, 2008 08:00 PM
BK600
Oct 13, 2007 10:53 AM
carmich132
Sep 18, 2006 02:44 PM
