fuel pump
Old 08-11-2005 | 02:44 PM
deslandese's Avatar
Default fuel pump
do you have ever see a fuel pump pumped gas and air.
My bike stop after about 1 hour and it has no gas in my hose. my tank is full and my hose is in good conditon.
Is it possible that my fuel pump pump the air???
When I exit the air on my hose and put gaz, the bike fonction during 1 hour about.
Old 08-11-2005 | 10:22 PM
InTheMaking's Avatar
Default RE: fuel pump
1. check petcock valve, do this by disconecting the hose from it and seeing if fuel pours out when its on.
if petcock works try this
2. put a volt meter or test light across the fuelpump lead wire and hit the starter should be 12v while starting or running.
if there is 12v try this
3. disconnect line after fuelpump try strarting and see if fuel comes out while starting.
post new message with found resaults.
Old 08-16-2005 | 12:39 PM
deslandese's Avatar
I did all that you told me and all fonction well.
My filter in my tank is clean and good. My pump fonction well.
But I think that it takes air when it pump
Old 04-08-2009 | 03:54 PM
atmonreal's Avatar
Default Fuel Pump Questions
Hey will a 1990 fuel pump from a CBR 600F fit a 1994 or 1996 CBR 600F2 and F3. Just hoping...
Old 04-08-2009 | 05:27 PM
tripicana's Avatar
it should work..
the OP's problem sounded kinda like his gas cap wasn't venting?
Kopi Ko
09-06-2024 12:02 AM
Rockshoxtora
08-12-2010 03:58 PM
Fool
F4i - Wanted
05-10-2010 02:05 PM
zblad
12-05-2008 01:14 AM
Quick Reply: fuel pump
