Fairing Install
Old Jul 25, 2013 | 10:32 AM
Azandford's Avatar
Default Fairing Install
First bike. 89 F1 I recently picked up for cheap. The current fairings are very rough and the side covers are zip tied on. I'm confused as to how the fairings are held on to the bike normally. I see the bolt holes on the fairings but nothing underneath to bolt into. This may be a stupid question, but some guidance would be appreciated. I found replacement fairings and want to know before I get started.
Old Jul 25, 2013 | 11:29 AM
sickcbr1k's Avatar
Is there any holes in the frame-work that correspond with the holes in the fairings? If not try looking near the area where the holes should be, to see if there are any missing bracket holes....if that makes sense..
Old Jul 25, 2013 | 05:27 PM
CorruptFile's Avatar
June 2013 ROTM
There are clip type nuts on the front stay, there are side fairing stays on the bottom of the case, and there are bolt holes on the frame above the footpegs.
Old Jul 31, 2013 | 05:59 PM
Azandford's Avatar
Thanks for the help. I just purchased all new fairings, takes about a month to make and ship out.
Another quick question. Where can I find replacement fairing bolts? Are they specific or can I just go to the hardware size and search the metric sizes?
Also, anyone know where I might find the 2 pieces that go on the inside of the front fairing around the gauges?
Old Aug 1, 2013 | 03:46 AM
Zachy72's Avatar
All the fairing bolts you can buy at the hardware store, they won't be perfect because Honda uses funny lengths. You can usually get them a MM or so either longer or shorter and gap them with some washers. The only ones you HAVE to buy from Honda will be the inspection panel clips. As those are pretty unique. At $13 a pop all 4 will costs around $55 with tax
Old Aug 2, 2013 | 09:08 PM
TahoeRider's Avatar
I got all mine from the local hardware store also. The thread pitch is a standard size (can't remember what is is), and should be pretty easy to find a length that works.
The 2 small panels around the gauges you'll probably have to search ebay/craigslist for. I don't think anyone is making reproductions of them so you're going to have to find a used set somewhere.
Old Aug 19, 2013 | 11:25 PM
greentowtruck's Avatar
New Member
I have been sizing some of the hardware on mine and they all seem to be 6mm x 1.0 thread pitch.
Reesie
Mar 1, 2013 07:25 PM
cobra1000rr
Apr 19, 2012 09:56 PM
nowensby
Feb 20, 2011 12:23 PM
nowensby
Feb 19, 2011 03:06 PM
OsinO
May 4, 2008 08:31 AM
