Exhaust/Radiator/Overheat - '87 CBR 600
Old Jul 27, 2008 | 03:33 PM
stinemonster's Avatar
Default Exhaust/Radiator/Overheat - '87 CBR 600
Have exhaust going into the radiator forcing the coolant into the overflow and causing the bike to over heat. Guessing it is the head gasket. No signs of water in the oil.
Got real bad after the temp gauge pegged Friday.
Any advice/tips/ideas are welcome.Planning on tearing into by Saturday August 9th.
Any cheap place to order gaskets? Unless someone gives me another place will be ordering them through cyclepartsnation.com.
Thanks
Old Aug 7, 2008 | 10:29 PM
Default RE: Exhaust/Radiator/Overheat - '87 CBR 600
Started tearing into the bike this week. Have the exhaust, carbs & valve cover off.
Definite signs of water/oil mixture in the valve cover.
Anything I need to know about the cam and/or timing before I pull the head off?
Any advice will help. Any advice besides "Take it to a shop".
Plan on pulling the head Saturday. I have the book for the bike and plan on looking it over before I go any further.
Old Aug 8, 2008 | 07:30 PM
grindpunk16's Avatar
few questions. do you ride the bike alot? how has the weather been up there, changing from hot to cold every day? is the oil in the crank case milky color?/
the reason why i ask these questions is because if you dont ride the bike or it has been real wierd temp changes it can cause condensation to build up in the air filter box and because the crank case vent is open no pcv valve condensation will make its way down into the top of the head. usually gets burnt away after riding. check the crank case oil and see what that looks like then go from there
Old Aug 9, 2008 | 11:55 PM
test
finally. it let me leave a post
Old Aug 10, 2008 | 12:04 AM
It was the head gasket. I'm going to TRY to leave pics.
see pic
solololos
Sep 19, 2013 06:53 PM
mike.bucci
Jul 1, 2011 07:29 PM
ibiggers
Apr 1, 2010 05:08 PM
BigNate354
Apr 21, 2008 01:19 PM
1k06rr
Feb 8, 2008 06:43 AM
