electrical problem...
Old Jun 29, 2010 | 03:56 PM
ConcealedDeath's Avatar
Default electrical problem...
I just got my 89 600 running today and after about 2 minutes of running it shuts off, including the neutral light on the dash. I turn the ignition a couple times and the neutral light came back on and the bike was able to start but only for a couple seconds. Then after turning the ignition key it did it once again but after the bike died again none of the electrical is working. I wasnt sure if my battery had just died so I attached jumper cables up and no lights on. So it isnt my battery or the main fuse (30 amp) i dont know what else it could be.
Hopefully someone knows how to fix this.
Thanks for any help!
Old Jun 30, 2010 | 10:22 AM
tripicana's Avatar
check all your connectors up at your main fuse panel near the instruments.
it would help to get a volt/multimeter and start checking where you have power and where you dont. it sounds like you have a bad or corroded connection somewhere.
unplug and replug all the connections a couple times to make sure you're getting good contact, and make sure they are clean.
Old Jun 30, 2010 | 04:38 PM
JesseAwesome's Avatar
Dieing cry of a Regulator/Rectifier?
Old Jul 1, 2010 | 09:35 AM
well it ended up being just a loose connection at the main fuse. so nothing major!
01daell
Sep 2, 2021 07:46 AM
kwood
Jun 1, 2020 09:53 AM
vfrman
Nov 16, 2008 10:06 AM
hridlehuber
Apr 5, 2006 04:11 AM
dunn929
Dec 6, 2005 12:50 PM
