Electrical gremlins
Electrical gremlins
O.k. So, my 1989 cbr seemed to have trouble keeping the battery charged. If it didn't start on first couple of tries it would kill the battery [even a new one.]
Then it wouldn't even light up, with a new battery. I checked for short but couldn't find any.
I put in a new relay switch. I got it to start by jumping it from a car battery. It was running very rough and the tacomiter was going up and down wildly.
So I replaced the rectifier, regulator. The battery still doen't seem to work. When I hook it up to a trickle charger the tac goes to 3, and the lights go on. When I press the start button eather the relay clicks or all the lights go out. When the lights go out , I turn the power off and then on agian and it comes back on.
This is a modern bike for me. I use to old bikes with simple wiring. I feel like I'm missing something obvious.
I went to the ladies only section, and boys you aint missin nothin!
thanks in advance for any help.
RE: Electrical gremlins
I suspect the stator is gone, and you have a LOT of issues that need to be addressed via volt/ohm meter to determine the source of the problems.
but majorly, look at your wiring harness for any ghetto riggings, and grounded wires/short circuits that may affect things such as your tach and other stuff. hell, be glad you HAVE a working tach, mine just sits pretty at 0 whether its running or at redline and hitting the limiter.
Flogger
01-20-2008 10:39 PM
