Electrical Disaster
Old Jul 26, 2008 | 11:52 PM
smokingmole's Avatar
Default Electrical Disaster
Much thanks to Kewl Breeze this post is where it should be!
Old Jul 26, 2008 | 11:57 PM
Default RE: Electrical Disaster
OK
i have come to realize that electrical is officially the worst
last night a connector musta come loose and it melted everything around it
Old Jul 26, 2008 | 11:58 PM
So, I've deduced that its the wiring that goes down to the right side clutch cover into the stator and that i melted the craaap outta the three prong connector, but i was hoping someone knew what gauge wires i should get to replace everything. Also, any ideas how this coulda happened besides the connector coming loose?
thanks guys
Today I took everything apart and discovered this lil' beauty:
Old Jul 26, 2008 | 11:59 PM
sorry for making a zillion posts but ive been trying to post this all day with ZERO success... this finally worked
Old Jul 27, 2008 | 12:17 AM
Kewl Breeze's Avatar
Retired Moderator
Only mods/admins can move posts.
I've moved the post for you per your request but please edit your original post with the post you want to make so it can remain in this section. Thanks
p.s. Don't u.se words such as (or intentionally misspell them):
L I K E
U S E
W H I L E
W H E R E
C O M P A R E
if you want better chances of your post making it through and u.se the "Preview" function before clicking "Submit Post" if you want to ensure your post will make it through. If it gives you an error in preview mode, click "Go Back to Post" and find the offending word and change it. (Problems will be fixed soon but for now that's the only way around it). There's a thread in suggestion/help section with more detail.
Old Jul 27, 2008 | 12:20 AM
ORIGINAL: Kewl Breeze
L I K E
U S E
W H I L E
W H E R E
C O M P A R E
Thank you very much! i will edit that in a second.
Old Jul 27, 2008 | 12:43 AM
OK, update:
i just got back from both autozone and pepboys. neither carry three pin connectors.
i picked up some 18 gauge wire, but after comparing it to the yellow wires on the bike it seems that the yellows are even smaller. if i cut the yellow and crimp it to the 18 gauge would that do the trick?
Also, anyone know the exact purpose of the three pin connectors besides making it simple to disconnect the wires to work on the non-electrical stuff? if thats the case, can i just conn3ct them? (making sure not to let them touch each other? i could us3 single pin connectors on each of the three wires... i have some of those
thanks guys
Old Jul 27, 2008 | 02:20 PM
Billistic's Avatar
ORIGINAL: smokingmole
OK, update:
thanks guys
Yes , you are correct and using some bullet connectors will do just fine. It seems that your melting connector problem is a common one, because the connection became loose and corroded over time. Go back to Pep Boys/ Autozone and get some little packets of dielectric grease. Since you have the tank off, disconnect those other connectors, clean them, and put some of the grease inside each connector.Also check for tightness. If one of those blade connectors seems loose , then give it a little squeeze with a pair of needle nose pliers and then reassemble. It doesn't matter which yellow wire get connected to which yellow wire. They can be connected in any order .Be sure that your crimps are good, again I would recommend insulated bullet connectors.
Old Jul 28, 2008 | 12:09 PM
ORIGINAL: Billistic
Billistic! Thanks, I did exactly that and it worked perfectly! i also picked up some contact cleaner (in addition to the dielectric grease) to clean the 21 year old connectors... i was a little freaked out to start it up again, this being my first electrical experience and realizing that i could blow the entire charging system, but she came back to life perfectly! I'll throw up some pics later tonight... Thanks for the help!
Joecbr
Oct 10, 2014 08:19 AM
jfkscbr600f3
May 14, 2010 02:28 AM
mdfirefighter
Sep 29, 2007 08:23 AM
bobjoezx
May 30, 2006 11:13 PM
bobjoezx
May 26, 2006 11:06 PM
