Does anyone know?
Old May 7, 2012 | 04:46 PM
sull625's Avatar
Default Does anyone know?
Does anyone out there know what the inside diameter of the coolant hose is on a 87' CBR600F?
Old May 7, 2012 | 06:21 PM
MadHattr059's Avatar
Can't say for sure. Try measuring the out-side and knock off a 1/4".
That should get you in the ballpark.
Ern
Old May 7, 2012 | 10:06 PM
sull625's Avatar
K will do. I am looking into purchasing a trail tech gauge system and I am guessing ill need it for temp gauge.
Old May 8, 2012 | 12:15 AM
87 cbr 600f's Avatar
Default pipes
i have 26mm outer diameter 4mm wall thickness so inside diameter is18mm this is from the hose off the water pump hope this helps
Old May 8, 2012 | 12:52 AM
Boxdgm's Avatar
I bought the universal vapor kit 752-601 and the sensor fit perfect in the radiator hose.
Old May 8, 2012 | 01:51 PM
sull625's Avatar
Just checked out the vapor kit 75-601 and that looks like it will work perfect thanks for your help.
