compatible fuel pump
Old Jul 4, 2007 | 11:29 AM
OLDbutFAST's Avatar
Default compatible fuel pump
I have a 89 600F with a bad fuel pump. Can anyone tell me it the fuel pumps from a f2 or f3 are the same? They appear to be but i'm not sure.
Old Jul 4, 2007 | 11:44 AM
drakito's Avatar
Default RE: compatible fuel pump
I'm not sure either, but if the inlet/outlet's are the same, it has the same psiand it works on 12 volts, you can easily make it work.
Old Jul 4, 2007 | 02:44 PM
rrasco's Avatar
i think i remember michigan stating the f3 works, use the search feature to search the f1 board for it.
Old Jul 4, 2007 | 03:33 PM
Micro Rotors's Avatar
OLDbutFAST,
When you find out, please post you findings here as I have an 89 but my pump is ok ... (for now). It could prove to be usefull information for others or if my pump goes on the fritz!
Thanks
Bill
Old Jul 4, 2007 | 03:54 PM
ras122's Avatar
I have been using a pump from a F3 for the past 2 years with no problems. I can't remember what year, either 95 or 98. The only thingis the wiring which was shorter on the newer pump.
Old Jul 4, 2007 | 07:33 PM
OLDbutFAST's Avatar
As ras just said, I found out a F3 pump will work if you make the wires on the pump longer
Old Jul 5, 2007 | 12:22 AM
Great info guy's. I will take note on that.
Bill
Old Jul 5, 2007 | 10:13 PM
gag1938's Avatar
I can't remember what car it was from...but I ran a fuel pump for five years from some little rice burner car. I just took the pump in and matched it up for size at the autozone. You just need a pump with a auto-shut off for line pressure of about 6psi. Double check the line pressure stat with someone who has a factory manual. Accel fuel pumps are available at O'reilly for about $30. It is a different shape but still small. I just got one for my 1982 Bronco. ( Cheap = good! )
Old Jul 8, 2007 | 07:29 PM
OLDbutFAST's Avatar
100 % sure that the F3 pump works 2 days ago my friend that I ride with had his fuel pump on his F3 go out.
Kopi Ko
Sep 6, 2024 12:02 AM
emtb88
Dec 8, 2011 01:44 PM
zblad
Dec 5, 2008 01:14 AM
blazinblaine
Jul 16, 2006 02:35 PM
