Clutch help!
Clutch help!
Hi all. I'm trying to reinstall my clutch after installing a shift kit., I'm stuck tho. I'm at the stage where I am installing the clutch outer. I cannot for the life of me get the outer to line up with the oil pump drive bosses. I push in on the outer while turning the oil pump sprocket, but it doesn't catch. I've tried using the butt if a hammer to knock it in too. Am I missing something?
Mine just slid right back together when I had it apart. If you take off the drive sprocket & clutch outer does it fit together fine off the bike? If I remember correctly when I did mine all I had to do was rotate the driven sprocket while pressing in the clutch outer and it popped right in. Maybe something is hanging up between the drive sprocket & clutch outer?
The oil pump drive is #1 in the schematic here 1987 Honda CBR600F Parts, 1987 Honda CBR600F OEM Parts - BikeBandit.com when I put mine back in it took me several tries to keep it lined up I had to take #4 out and put it in from the front after I had everything in and lined up. If its not lined up with the pegs the clutch basket won't set all the way.
I hope the link works right if it doesnt its bike bandit under transmission then clutch
Zandaloo
08-22-2013 03:26 PM
Bordo
09-21-2012 07:33 PM
02f4irider
03-06-2009 07:50 PM
