CBR600F-H Wiring Loom
Old 07-07-2017, 06:46 AM
CaBaRet's Avatar
Hi Connor , when you said you jumped the starter solenoid , I take it you bridged the posts with a screwdriver or something like that, did the engine turn
(with key in and on)
Old 07-07-2017, 07:05 AM
Jardine12's Avatar
it was a while ago now but when I did it I followed the manual to check it was working which basically said connect the battery then bridge the connections, but nothing else was connected to the solonoid
Old 07-07-2017, 07:11 AM
CaBaRet's Avatar
Hi, yes what I'm getting at is that the solenoid might be b*******d, if you have it all connected and ready to go try bridging the starter solenoid, and if the engine turns then the solenoid is naff
Old 07-07-2017, 07:13 AM
Jardine12's Avatar
Thanks man I'll give that a go tomorrow and report back
Old 07-08-2017, 02:54 PM
Jardine12's Avatar
When i bridge the solenoid with everything connected it does turn the engine, but is it normal that doing such a thing could blow my main fuse?
Old 07-08-2017, 03:03 PM
CaBaRet's Avatar
Hi , that means the solenoid is no good and why you cant start it off the button you'll need a new one, their cheap enough of e-bay
Honda CBR600F (1) starter relay, solenoid (1987-1990 H/J/K/L models) | eBay
Also clean up the starter button on the handle bars
Old 07-08-2017, 03:06 PM
Jardine12's Avatar
Thanks man, ill get that ordered within the week and report back when I've tried it, there will probably be a lot of this.
Should rename the thread, Connors troubleshooting manual.
Old 07-08-2017, 03:08 PM
CaBaRet's Avatar
And did it blow the 30amp fuse when you did it
Old 07-08-2017, 03:27 PM
Jardine12's Avatar
Yeah the 30 amp fuse blew
Old 07-08-2017, 05:18 PM
CaBaRet's Avatar
When installing check solenoid that's coming out for telltale signs , also check wires and connectors coming and going from solenoid for shorts
Quick Reply: CBR600F-H Wiring Loom
