CBR600 F1 startup/crank troubleshooting
Old Feb 19, 2011 | 10:32 PM
craywm's Avatar
Default CBR600 F1 startup/crank troubleshooting
Hey guys, I just bought a 1988 Honda CBR 600F and went to start it up with a battery from my 250 scooter. it didnt have the cranking power so i hooked up a car starter to it (which puts out 900 amps) and it cranked until that car starter died (it needed a charge anyway). the battery that i had was crap, it cant hold any charge. But when I hooked up my other car started (which is a direct feed from the wall) i trickled it for 5 min at 2 amps then put it up to 12 amps. turned the key and his start. nothing. not even a crank. I know putting 900 amps through the thing wasnt smart.. but it was cranking just fine 5 minutes earlier. I already know the carbs need readjustment before crank time can be decreased but why would it suddenly not even crank AT ALL!! i plugged the 900 amper back in and same story.. not even a crank. there wasnt even any bad nooises before it started. All the electrics work from the headlight to the turnsignals to the meter lights.. but i go to hit the start button and nothing happens.. I hope i didnt fry my starter.. (AND YES.. THE BIKE IS IN THE "RUN" POSITION) I am going to buy a new battery today but is there any electrical issues that could be causing this as well?
Oh yeah, I couldnt find a technical/trouble shooting section here so I just posted under new member. if you could direct me to the proper posting place too thatd be great. THANKS ALL!
Old Feb 20, 2011 | 12:00 AM
scorpionvmu's Avatar
2011 Ride of the Year
did you check all the fuses???
and it might just be the battery...
if not i would check the starter.
advise as a car mech. know nothing about the bikes yet. but thats what i would do first.
Old Feb 20, 2011 | 01:55 AM
jp_greenville13's Avatar
100:1 you cooked the solenoid.
1:100 you cooked the switch
Old Feb 20, 2011 | 09:00 AM
craywm's Avatar
I considered that I cooked the solenoid but didnt think so since I didnt hear or smell anything bad. What do you mean by switch too? The starter switch? How could that happen? Still havnt checked fuses but I doubt its that since all other electrics work!
Old Feb 20, 2011 | 12:09 PM
craywm's Avatar
Just replaced the battery and checked the solenoid fuse. Both were good.. Still not even a crank. Again all electrics work just wont crank a bit
Old Feb 20, 2011 | 12:32 PM
craywm's Avatar
Turned it on and the oil light is on.. Could this be a problem? Also does this thing have a fuse box?
Old Feb 20, 2011 | 12:43 PM
craywm's Avatar
Old Feb 20, 2011 | 04:18 PM
thrasher572's Avatar
You let it turn over until your booster drained? You probably cooked the armature in the starter or the brushes.
Old Feb 20, 2011 | 05:18 PM
craywm's Avatar
Starter motor is good. Believe I cooked the solenoid. I checked all fuses and checked the starter. Used a multimeter to test voltage. Everything points to the solenoid, though all electrics still work. Sound right to you guys?
