CARBURETOR f2 in f1
RE: CARBURETOR f2 in f1
depending on what year F1 you have, stock throttle bores are 32mm or 34mm. measure or find out what the f2 throttle bores are. next, you will have to see how wide the whole assembly is from bore to bore. they may not line up exactly with the intake tract. i don't know how off it will be. you might be able to get away with it if it's not off by too much. if you have f1 carb set, you might be able to use the shorter fuel rails, springs, etc, to narrow down the assembly to fit as long as the throttle bores aren't too much larger than the intake tracts or the stock setup.
kagmyster00
08-21-2008 09:20 AM
