Carb choke linkage issue - any ideas?
Hi,
This is my first post on here - here goes
I have a 1990 600 & a couple of months back pulled the carbs off & cleaned them all up.
I finally got around to starting the bike up today.
It took a bit of persuasion, but considering it has no air box or can on it at the moment I felt it ran quite well considering it last ran nearly 3 years ago & then that was only briefly too!
The problem I have is that the choke linkage isn't working, I am having to use 3 screwdrivers to open the chokes. The carb on the right works ok as the rod is directly attached to it.
When I had them off I cleaned the long rod up & it moves freely through the carb bodies, but just wont open the chokes when it's all connected up.
Is there a knack to setting the rod up - I can't see anything in the manual. The cable pulls okay by the way - when the carbs were off the bike it didn't work right by pulling on the rod!
Any suggestions greatly received
Cheers,
Impman71
Cheers,
Impman71
on each carb. theres that bracket deal that the choke rod goes through, and each of them has a screw except the last one, because its like the base. when the choke isnt being pulled you have to tighten these screws and make sure that when you pull the choke that its opening all the carbs the same. ill see if i can maybe post a picture or two later
Thanks Sandrailman, I feel a rite **** for not thanking you before, sorry, I thought I had!
Another bike arrived a little while ago, that has also turned into a project
Your video helped (I had the carbs back off the other day), I had straightened the bracket that is pushed by the lever mechanism thinking this might have been the cause, but could see on yours in the vid, that it's meant to be curved!
I unscrewed the 2 left hand locking screws & concentated on getting the linkage to work properly on the 2nd from right carb. Ended up bending the claws so that they were pulling the pin on the carb parellel & now the chokes are working properly on all 4 carbs .
I just need some dry weather now, so I can get on & do a bit more to it!
Cheers,
Colin
Cheers,
Colin
