Cane Before and after
Both the front and rear are on the soft side. Instead of fiddling around with it, pumping up the front and adjusting the rear preload I will get it to a shop and have them cater it to my needs exactly. Otherwise it ride pretty good and stable. I am sure if I kicked it up a bit it'd be twitchy and nimble with some stability thrown out.
not sure what they can do that you can't do yourself in about 10 minutes. the front is not adjustable other than the air pressure or a higher weight oil. the rear is just a matter of spring preload and the clicker. seriously, you are going to spend money on adjusting the rear shock and they will be ripping you off. hate to see you spend $$ that you don't have to!
