Bike runs like crap
Did you check the fuel pump output? You know.... measure it? If you have cleaned the carbs 3 times then I'm assuming that you are now very familiar with them. I don't know how you will know if a float is sticking or not.... anyone.... Bueller...... sucks to have 4 individual carbs. Did you totally tear them down and clean everything. When you reassembled them are you sure that everything went back together right. Reason why is.... there are so many little parts and so many detailed things that can go wrong.. clogged jets.. sticky floats... vacuum leaks. That's why I'm asking. Hard enough to troubleshoot 1 carb.
The first time, I did just spray some carb cleaner through them but once that didn't fix them I took each one off the rack and took everything out of them and cleaned themand used compressed air through them. I am not going to spend $200 onparts to fix them. I think I may just get some off of a running bike for $100.
swisherred
04-05-2009 01:15 AM
