'89 Stopped Running
Old 10-05-2008, 03:56 PM
Default RE: '89 Stopped Running
your first statement with the fuel, suggests you may need to switch to reserve, and see if it flows fuel from there. it should be a constant flow of fuel.
Old 10-05-2008, 04:52 PM
tds94probe's Avatar
uh this is usuallly not recommended, but try dumping a SMALL smount fo fuel down each carb, see if it runs then.
Old 10-05-2008, 06:59 PM
Vyxor's Avatar
I already tried fuel in the carbs, I got it to start that way, but it wouldn't keep running (no more fuel coming in, I guess, but I can't be totally sure that's the reason)
As for the reserve, I can try that, but as far as I know the petcock hasn't worked since I got the bike, the fuel flow never stops no matter what it is turned to...I'll try again with the hoses off just to see what the flow is like though, I'm not quite sure what it will be like.
What exactly is the difference between 'On' and 'Reserve' for the petcock anyways?
Old 10-05-2008, 07:26 PM
Default RE: '
I normally spray gasoline into the carbs with a small CLEAN spray bottle when I am testing out various things ... this allows the bike to keep running.
Old 10-05-2008, 08:58 PM
Default RE: '
difference between ON and RESERVE is the height of the pickup. the reserve pickup is at THE bottom of your tank, ON is a good bit higher.
this is going to sound VERY stupid, but is there actually fuel in your tank?
cbr600-michael
04-05-2015 03:55 PM
mrclean667
11-20-2013 01:50 PM
Mattson
01-18-2013 01:50 PM
cbrfreak47
10-08-2011 10:31 AM
TheFirm799
11-16-2005 06:24 AM
Quick Reply: '89 Stopped Running
