87 Hurricane build
Old Sep 15, 2013 | 08:40 AM
  #71
ben12178's Avatar
Ok so I found what looks like a good used cylinder set and bought it, I also ordered a new head and base gasket. Hopefully the next update I make is that it running like a champ again cause if anything else expensive happens I don't know if I will be able to fix it.
Old Jun 20, 2015 | 12:40 AM
  #72
ben12178's Avatar
Wow update to an old thread but life happened and my bikes had to sit for a while. I was able to clean my carbs and make an overflow for my hurricane. This will probably be a temporary setup until I can clean it up.
Once it stops raining every day I'll be able to get it out and ride again
Old Jun 22, 2015 | 01:47 PM
  #73
dennisgb's Avatar
Why do you need an overflow?
Old Jun 23, 2015 | 10:17 AM
  #74
ben12178's Avatar
With the tail and swingarm swaps I couldn't use the stock coolant reservoir so I figured I'd use an aluminum water bottle. I'll probably look for a smaller bottle or a different bikes reservoir to clean up the looks. I definitely need to clean up the wiring though.
Old Jun 23, 2015 | 04:41 PM
  #75
dennisgb's Avatar
Hi Ben,
I forgot all the mods you made to your bike. Looking back at the pictures there should be a way to get an overflow bottle inside the frame...likely a smaller one like you said.
I completely reworked the wiring harness on the RR bike to clean it up. You can re-wrap them pretty easy. The routing is important to get a clean look and still connect everything properly.
Old Jun 23, 2015 | 11:08 PM
  #76
ben12178's Avatar
Yeah I've done quite a bit. The big bottle is temporary to be able to ride this season. I'm thinking I'll be able to fit something smaller close to where the stock overflow was. Re doing the harness is on my list as well but it's been 2 years since I could ride so since it's up and running for now I'll ride as is and do work this winter.
Old Nov 26, 2016 | 06:54 AM
  #77
beyprofab's Avatar
was the centre line of swingarm accurate after only trimming the one side to fit in frame?
Old Nov 26, 2016 | 11:38 AM
  #78
dennisgb's Avatar
Not sure if Ben is still active. If he is he will probably explain this better, but the cut on the one side of the swing arm was done to get the sprockets to line up.
You also have to do custom dog bone mounts for the shock to get it to work. He explains this early in the thread and shows pictures.
This is his quote on the swing arm.
Originally Posted by ben12178
I still need to get a 525 front sprocket to match the rr rear but I used my 530 chain and its dead on. Thats why I cut it on the other side but I was still taking a risk that it wouldnt line up because I had the engine out when I was fitting the swinger.
Old Nov 27, 2016 | 07:11 AM
  #79
ben12178's Avatar
Yes everything lined up very well by cutting the side that the brakes are on.
Old Nov 28, 2016 | 08:41 AM
  #80
dennisgb's Avatar
Hi Ben,
Do you still have your bike?
