1990 cbr600f no spark or fuel pumpyyy
Old Apr 12, 2026 | 12:15 PM
John850t5's Avatar
Default 1990 cbr600f no spark or fuel pumpyyy
Been looking at my 1990 cbr600 today, have no spark at all or fuel pump power. Ive tried live power to the pump and it works. Bridged rhe wire that goes to the fuel pump relay and that did kick the pump in so I know the kill switch works.
Ive got 12v at the coils + terminal. Ive checked and cant find any broken wires or fuses. The only thing I can think of is the cdi box but would that kill spark and fuel pump when you turn ignition on?
Old Apr 12, 2026 | 02:10 PM
Ed Harris's Avatar
Have you checked the interlock? The side stand, neutral and clutch switches.
Old Apr 12, 2026 | 02:46 PM
John850t5's Avatar
What do you mean by the interlock?
Its getting signal for neutral so I assume thats okay, ive tried it with the side stand up and down but in neutral wouldn't that discard the side stand anyway?
Old Apr 12, 2026 | 03:20 PM
Ed Harris's Avatar
That's why it's an interlock :-)
The switches are interconnected so, yes, if it's in neutral and the neutral signal is connected to the ECU then you're OK.
Old Apr 13, 2026 | 06:02 AM
John850t5's Avatar
Okay that makes sense, im not really clued up on bikes. Got a new cdi coming this week to try so hopefully that might solve it
Old Apr 16, 2026 | 04:38 PM
John850t5's Avatar
Ive tried a new cdi and its exactly the same, no fuel pump and no spark. Ive got 12v still on both terminals on the coils but its still not switching. Ive got 12 at the fuel pump relay and the from the relay to the pump its not kicking out any power with 2 different fuel pump relays.
The cdi box I tried is from a 1994, could this cause no spark still. Im gunna try a new 1990 wiring loom and ignition seitxh to rule that out next
Old Yesterday | 04:57 PM
John850t5's Avatar
Default Update
I have realised ive been testing only 1 coil. The coil leads loop over so the left hand coil does the 2 outer cylinder and the right coil does the inner 2 coils. My left coil is dead. Ive tried swapping the feed wires round for the coils and both time i had spark on the right coil but not on the left so a new coil should cure my problem.
I still however have no fuel pump prime despite having power to the fuel pump relay and tried a different relay. What else could cause spark but no fuel pump???
unnecessary
Apr 29, 2020 04:11 PM
squidhead
Apr 1, 2020 12:15 AM
kentuckydiesel
Jan 7, 2009 07:24 PM
moneytimetyccoon
Mar 20, 2008 06:49 PM
egglog12
Nov 18, 2006 02:31 AM
