1987 hurricane 600f Can't Shift from 1st gear to Neutral
1987 hurricane 600f Can't Shift from 1st gear to Neutral while bike is on, the gear seems to be jammed when I'm at a complete stop, it shifts fine from 1st to Neutral as soon as I turn the bike off, but when the bike is on, and at a complete stop, I can't get out of 1st gear to go to Neutral or even 2nd gear!
any advice?
thanks
any advice?
thanks
RE: 1987 hurricane 600f Can't Shift from 1st gear to Neutral
jammed = hard to shift
- clutch drag, possibly improperly adjusted clutch cable
- bent shift fork
- bent shift spindle
- bent shift claw
- sticking shift drum stopper
- incorrect engine oil weight, very unlikely in your case
- faulty clutch lifter, located on inside of right crankcase cover
- faulty gear shift spindle
- faulty gear shift linkage
- faulty drum shifter
i would say it is drum shifter, shift claw, or shift fork. the latter 2 can only be checked by removing the engine and splitting the cases.
have you tryed rolling the bike backwards a little bit before shifting from 1st to neutral when bike is operating?
- bent shift fork
- bent shift claw
tylergswan
05-19-2011 09:09 PM
