stumble
Old Jul 16, 2007 | 10:48 AM
mihomie's Avatar
Default stumble
when taking off from a dead stop there is a slight stubmle aroun 1500-2000 rpm, then it really takes off if i am not paying attention. does anyone else experience tis? or can it be linked to the flapper? i have not done the flapper disconnect to see if it improves.
Old Jul 16, 2007 | 01:53 PM
Thorsome's Avatar
Default RE: stumble
My '05does this too, but only when the radiator fan is running.
Old Jul 16, 2007 | 05:27 PM
baxsom's Avatar
Default RE: stumble
very common on the 1000RR
2000-2500 rpm is the rpm range for this
flapper mod, gearing change and custom map are the best ways in order of expense to correct this
Old Jul 16, 2007 | 10:01 PM
SD2007's Avatar
Default RE: stumble
[quote]ORIGINAL: Thorsome
[quote]
The flapper mod didn't fix this on my bike, it's almost worse now. A PCIII seems to be the weapon of choice to battle the dreaded stumble.
Old Jul 17, 2007 | 02:48 PM
mininsx's Avatar
Default RE: stumble
I honestly didn't have hesitation like I've heard others talk about, until I did the flapper mod-it was so much smoother taking off from a stop. You should try it if you haven't already.
Old Jul 18, 2007 | 06:15 AM
baxsom's Avatar
Default RE: stumble
ORIGINAL: mininsx
i am kinda confused by this post
did the flapper give you hesitatation or no
jetson1000f
Apr 10, 2011 08:12 PM
Camman
Sep 1, 2007 07:05 PM
78sharpshooter
May 9, 2007 03:30 PM
acs1960
Jan 9, 2007 10:56 PM
929ER
Jun 2, 2005 02:25 AM
