CBR 1000 STUMBLE
Old Aug 29, 2007 | 05:04 PM
Camman's Avatar
Default CBR 1000 STUMBLE
I've got a little stumble below 3000 RPM's? Above 3Grand it runs like a champ! Can anyone help?
Old Aug 29, 2007 | 05:27 PM
asrguy's Avatar
Default RE: CBR 1000 STUMBLE
are you stock or modded? try a pc3 with a map of your current setup and maybe that will help.
Old Aug 29, 2007 | 06:52 PM
mihomie's Avatar
i did the flapper disconnect, and installed a pciii. it has eliminated about 70% of the stumble. the pciii was well worth the money the midrange feels much stronger on the bike now. and the flapper is a freebee did it first. it did make an improvement but did not eliminate the issue.
Old Aug 29, 2007 | 07:49 PM
baxsom's Avatar
there is a classic stumble at 2500 rpms on these bikes. flapper helps a little, custom map is really the only way to go.
you can try my map. it was tuned on a load control dyno so i had them specifically take the time to clean up the stumble. torque went up 15 ft/lbs after the map
Old Aug 29, 2007 | 09:55 PM
tomc1965's Avatar
Do you have to have a PCIII to load a custom map?
Baxsom did you have any mods before you got the custom map created?
Old Aug 30, 2007 | 05:23 AM
baxsom's Avatar
ORIGINAL: tomc1965
arata pipe
bmc race filters
a tech intake
and yes there is no way to alter the oem ecu without a fuel management device
Old Aug 30, 2007 | 10:43 AM
RICHS65's Avatar
PCIII and custom map. No problems after that.
Old Aug 30, 2007 | 11:23 AM
mihomie's Avatar
stupid question but does anyone have a custom map for a stock pipe
Old Aug 30, 2007 | 07:31 PM
Camman's Avatar
Baxsom, Yeah can I try your map I'm also running a full arata. I had my bike also tuned on a dyno. But it was tuned more for the top end. So I'm willing too try anything to help don't want to pay 250 for another tune.
Old Aug 31, 2007 | 07:32 AM
baxsom's Avatar
you can download it here
http://www.1000rr.net/vb/showthread.php?t=20934
same username, there are also a lot other maps there that may be even closer to what you have
available for download
