Still overheating
Hi all im still having trouble with my 07 blade overheating. My rad went pop so sourced a new 1 fitted it flushed and filled with coolant but still happened. Changed the water pump rad cap t stat and houseing and temp sensor. Flushed and filled again burped and it runs fine outside the house not overheating. But take it for a ride its fine running at normal speeds but when u stop in heats up and spits the water out. But thistime I stopped and took the fairing off and the rad was low on coolant but the overflow bottle was upto the top.Could it be a blockage? If so how do you find it and fix it. Please please help its doing my **** in..
