Shogun no cuts
Old Dec 20, 2006 | 06:11 PM
dizzie56's Avatar
Default Shogun no cuts
Ok, the directions are not really clear on where to mount these. Anybody know? Im thinkin it says to drill into my frame but i dont know where and rather not if i dont have to.
Old Dec 20, 2006 | 09:44 PM
MgA_ODEN's Avatar
Default RE: Shogun no cuts
No cut also means No drill [8D]
Old Dec 20, 2006 | 09:47 PM
MgA_ODEN's Avatar
Found a link for ya[&:]
http://hooliganbiketech.dynup.net/ho...gunsliders.htm
Old Dec 21, 2006 | 02:26 PM
dizzie56's Avatar
thanks, i know they are crappy but i ordered them along time ago and dont have the money to put on some cuts
Old Dec 24, 2006 | 03:42 AM
buckward's Avatar
No cuts are great! Shogun makes a great product and you can call thier vendor Moto911.com @ 949-453-9111 Ext: 103 and talk with Paul. He walked me through the install. You remove both left and right fairings, remove the top motor mount bolts-Use their supplied bolts, Long bolt and short slider on "right" throttle side of bike and short bolt long slidder on left "clutch" side of bike. Be sure to use supplied spacers to pull fairings out a little when re-installing both farings on the "bracketed" bolts and use thier fairing bolts instead of the ones that came on the bike. They are longer so the spacers can be used.
Old Dec 24, 2006 | 03:59 AM
buckward's Avatar
P.S. the link from MgA_ODEN shows a problem if the bike is dropped "denting or bending" a cooling elbow and stating that the motor has to be "dropped" for it to be replaced, well my 06 slider installation let me position the "shoguns" out of harms way if droppedso as not to dent, crease, or crack the "water-elbow". I think the pic. in this link is of a older cbr1000 (04-05), the fairingsare different on those modelsthan the 06's/
Old Dec 26, 2006 | 12:07 PM
dizzie56's Avatar
yeah it is a pic of the 04-05 model, i got the 05 so im ****e out of luck if i drop it. i wouldnt have gotten them if i knew that they would bend up that part and in order to fix it u have to drop the engine. o well, just have to save up for some better ones
Old Dec 26, 2006 | 05:30 PM
MgA_ODEN's Avatar
The trick is to never use them
Old Dec 26, 2006 | 06:36 PM
dizzie56's Avatar
lol, yeah well i tried not havin to use my fairings before as a slider and that didnt exactly work out either
Rod38um
Aug 6, 2008 08:30 AM
BigCountryBllr
May 13, 2008 09:43 PM
lewis813
May 11, 2008 10:48 AM
dizzie56
Apr 30, 2007 04:44 PM
Socrates
Apr 28, 2006 07:48 PM
