shift light indicator
Hey guys, i tried searching for this but couldnt find it...Can someone please tell me how to set the shift light indicator on my 2004 1000rr? When i bought mine i didnt get a owners manual..
Thanks
LUKE
Thanks
LUKE
1) Press and hold the SEL button, then turn on the ignition switch. Kepp the SEL button pressed in until the initial display is completed. The tachometer needle moves to its preset position.
2) Each time you press the RESET button, the tachometer meter will move by an increment of 250rpm. Press and hold the RESET button for more than one second, the tachometer needle will move by an increment of 1,000rpm. When the needle exceeds the allowable range, it will automatically return to 4,000rpm. After completing the selection, press the SEL button, and proceed to the selecting display for the indicator.
3) You can choose from 9 different indicator displays. Press the RESET button repeatedly to view available displays. Once you reach the display you want, press the SEL button. Then turn off the ignition switch to register your selection.
