shift light indicator
Old Mar 21, 2006 | 08:24 AM
recker's Avatar
Default shift light indicator
Hey guys, i tried searching for this but couldnt find it...Can someone please tell me how to set the shift light indicator on my 2004 1000rr? When i bought mine i didnt get a owners manual..
Thanks
LUKE
Old Mar 21, 2006 | 04:41 PM
Falcon9901's Avatar
Default RE: shift light indicator
1) Press and hold the SEL button, then turn on the ignition switch. Kepp the SEL button pressed in until the initial display is completed. The tachometer needle moves to its preset position.
2) Each time you press the RESET button, the tachometer meter will move by an increment of 250rpm. Press and hold the RESET button for more than one second, the tachometer needle will move by an increment of 1,000rpm. When the needle exceeds the allowable range, it will automatically return to 4,000rpm. After completing the selection, press the SEL button, and proceed to the selecting display for the indicator.
3) You can choose from 9 different indicator displays. Press the RESET button repeatedly to view available displays. Once you reach the display you want, press the SEL button. Then turn off the ignition switch to register your selection.
Old Mar 22, 2006 | 01:39 AM
recker's Avatar
Thanks heaps mate just did it!!!!
Raptor5150
Jul 26, 2012 04:28 PM
750954
Jun 25, 2009 03:09 PM
dragonium25
Jul 8, 2006 06:32 AM
recker
Mar 21, 2006 09:09 AM
Thorsome
Sep 12, 2005 03:18 PM
