Repsol Tank Pad
RE: Repsol Tank Pad
Tank Slapper. Goes on clear and does not cover the paint. This is more of a cover and not a pad.
http://www.thetankslapper.biz/
RE: Repsol Tank Pad
ORIGINAL: txtx
Some advice from someone that has installed them on his 1000RR. Forget the pieces that go anywhere except for the 3 piece tank set. Stretching them around a corner without bubbling will drive you to a mental hospital. Yes, heat help, but come on, they were cut to go half way over the "1000RR" decal on the side of the rear fairings.
As for the tank protectors, they installed pretty good, time consuming the first time you do it. They don't want to contour really well right off the bat either. Persistence is the key. Get them as good as you can without losing your sanity and let them be for a few days. They'll form a memory to your tank and then you can remove them and re-install them with much better results. Good thing they are cheap.
They are not as invisible as they show to be on their website. When freshly installed, they let the brilliant red shine through. The next day, after the water evaporated out from under them and those little white specs appeared in one tiny corner I noticed the color of the tank wa a tad darker where the pads are and the texture isn't as smooth as the tank. Not a complete waste though, they do protect my tank from my pants and jacket which is what I wanted them to do.
I went ahead and ordered a second look tank bra, all black for mine. Doesn't help you since you want to see your decals.
RE: Repsol Tank Pad
If you are talking about the tank slappers, they make them for the tank, the headlights, the front fairings and the rear. A multi contour bend is a real pain, dealing with one is OK.
Another options is the second look tank bra. If you didn't check them out, you might want to. They make them to blend in with the graphics. I just didn't want that is why I am getting a black one. They might do a Repsol for a little extra.
SACBR
06-19-2011 11:09 PM
