Recommened Service?????
Old Nov 2, 2006 | 02:06 PM
NC CBR1K's Avatar
Default Recommened Service?????
I have a 2006 1krr and it has had the first 600 miles service....does anyone know when the next time it needs to go in??? Also, when my bike is in neutral and I put it in first it jumps real hard.....is this common??? thanks
Old Nov 2, 2006 | 05:41 PM
simo1000rr's Avatar
Default RE: Recommened Service?????
i just got my bike 1000rr 06 .. a couple months ago and it has 150 miles on it .. since the first day i got it does the same thing when i shift to the first gear from neutral it jumbs hard i thou i was the only one .. .????? i hope its common cuz it will **** me off to have problem with a brand new bike.
Old Nov 2, 2006 | 06:50 PM
NC CBR1K's Avatar
i find if your rolling a little bit, it doesnt do it as bad...have you asked the dealership about it yet
Old Nov 2, 2006 | 06:55 PM
NC CBR1K's Avatar
i just called the dealership and the service manager told me it was completely normal for it to jump a little......so your cool
Old Nov 2, 2006 | 07:32 PM
CBRCRF's Avatar
My 06 does it too.
Look in the owners guide, It should have a log and a schedule for maint.
Old Nov 9, 2006 | 10:08 PM
Jesse0376's Avatar
im glad the jump is normal mine does it to pretty hard but i have 3500 miles on my bike never did the 600 oil change
Old Nov 10, 2006 | 12:56 PM
mininsx's Avatar
The next service after the initial 600 is at 4,000 miles.
Old Nov 10, 2006 | 03:02 PM
FATHEADS1KRR's Avatar
Make sure your idle is set properly, and as low as possible. The lower it is the less clunk you'll get.
Old Nov 10, 2006 | 05:58 PM
r1b11963's Avatar
ORIGINAL: FATHEADS1KRR
So what is the proper idle? i think mine is running a little too high and it makes the temp to be around 180 and nothing less than 177.
Old Nov 10, 2006 | 07:11 PM
That temp is normal . Idle should be 1200-1300 rpms. I stick closer to 11. It has to be adjusted a lot too. Thought it was just my bike at first, but have seen/heard it from other.
