Problem with gears need some help
Old Jul 13, 2006 | 08:57 PM
cbrrookie's Avatar
Default Problem with gears need some help
Are any of you having any problems when you come to a stop light
and you have to put the bike in neutral and than after a while putting it in first again?
I can put it in neutral but the gear goes in hard and its loud I hate feeling that clanck.
It just doesn't sound good Can I do anything?
I would like some help thanks in advance.
Old Jul 13, 2006 | 09:10 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: Problem with gears need some help
If you're having trouble getting it back in first then roll forward or backward about a foot and it should go in easy. The "clunk" is normal when it goes in first -- for less "clunk" lower your idle speed to 1150 - 1200 rpm.
Old Jul 13, 2006 | 09:17 PM
cbrrookie's Avatar
I ll try that i'm running the bike at roughly 1500
i htought the bike dindn't like it that low because of the chug.
Old Jul 13, 2006 | 10:29 PM
I like the idle in the low range because, like you, I find the clunk to be an undesired event. Just give it a bit of gas when starting off to prevent lugging and it'll be just fine. Even though it's hydraulic, the 1kRR's clutch is like buttah .... smoooothe as silk.
Old Jul 13, 2006 | 11:00 PM
cbrrookie's Avatar
thanks a lot man I just tried it and its a lot better.
gotta love this site thanks for the info.
xX35ReapeR35Xx
Jun 9, 2013 08:35 PM
HungusMaximist
Apr 11, 2008 02:23 AM
NOSTUPIDZONE
Aug 4, 2007 03:30 PM
mikey1297
Jun 28, 2007 12:20 AM
yamihonda
Jan 18, 2007 12:22 PM
