Need help
I have had my 06 CBR parked in my enclosed trailer for about a month. This past Saturday it was decently warm so I got it out and did a little riding. She fired right up but the battery was a little weak. I needed to get some stuff out of the trailer yesterday and the battery just couldn't get it fired up before it completely dumped. So I took it in the shop and hooked it up to the battery charger for a little while and it fired up after 20 minutes. So to make a long story short when I got to the shop this morning I hooked the charger up again just to make sure the battery had a good charge. Well a couple hours later I went to start up the bike and it tried to fire up but it just wouldn't catch and eventually all it would do is just turn over with no effort in trying to fire. Any ideas what the heck I have done? Could I have fouled out the spark plugs?
Normally I'd guessfouled plugs, water in the fuel system or a problem with the fuel pump / injectors. But since you just had it running a few days ago I'm not sure what to think. This sounds similar to a thread I saw on 1000rr.net, and if I remember rightthe bike fired up again after the battery was replaced.
ORIGINAL: BadX
Sounds wierd that replacing a charged battery would fix the problem but when i did try firing it up this morning the battery died quickly so I guess I will try that first.
There is also a chance that all of that slow cranking could have fouled plugs too. So you may need a battery, but dont completely rule out fouled plugs either. Its very easy to do when its cold out.
ORIGINAL: TheX
If you're the BadX I guess I get to be the good one?
It was fun to ride but nothing like the CBR
