Need to do Oil Change..
RE: Need to do Oil Change..
Not sure for brake and clutch fluid, recently did my oil change, picked this up at my nearby dealer, washer, 10W-30 full synthetic HP4 and filter, also,dont forget to purchase the tool to remove the filter if you dont have one already. pretty easy job, painless and quick, but for oil I recomend, Repsol 10w-50 its a better buy. I dont know why I went with the Honda's HP4 10/30 not worth it.....go repsol.
ORIGINAL: Draco88
Just out of curiosity. . why do you feel the need to change the brade and clutch fluids?
just in case the clutch fluid is supposed to be black. it happens. you cant stop it
after the engine is good and broken in you really dont need to change the oil that often
it has been proven that even after 5K miles an engine with repsol in it was still protected just as well as when the oil was first put in.
i know its cheap insurance but amsoil is pricey (although a damn good oil)
