mods complete!
Old May 14, 2007 | 07:43 AM
dwhite645's Avatar
Default RE: mods complete!
ORIGINAL: Daca
Looks coool.
BTW can you explain the way you cut black plastic arround the pipe ....? I wana use Larry's FE with stock pipe. Any closer pics ...?
Thanks
It's actually a seperate piece. When you unbolt the whole mudflap assembly - turn signals, license bracket, license light, and all that stuff from the subframe, you'll see that it unhooks from the mudflap itself. Then it's attached, as it was before hand, to the top of the heatshield. If you pull your passenger seat off, look towards the rear and you'll see a 5mm allen head screw on top. That holds that black piece on above the heatshield. Looks much cleaner than just the aluminumheatshield.
Old May 14, 2007 | 08:22 AM
C4's Avatar
C4
Size:  65.8 KBName:  100_1153.jpg
Size:  100.0 KBName:  100_1152.jpg
Size:  70.1 KBName:  100_1144.jpg
here is a close up of the larrys fe kit.
Old May 14, 2007 | 05:02 PM
CBR1000's Avatar
Looks good. Missouri tags? Do you ride near KC? I ride with two other '06 1000RR's
if you interested and nearby.
speedygonzalez954RR
Oct 22, 2008 07:15 PM
Drekkyk
Aug 1, 2007 07:12 PM
Raptorsj
Jun 16, 2007 10:03 PM
