MIRROR MODS
RE: MIRROR MODS
ITS NICE TO SEE SOME PEOPLE LIKE MY MIRROR MODS AND SOME DON"T BUT REASON I DID THIS IS THAT I HATE MIRRORS AND I HATE INDICATORS SO TO HAVE THEM TOGETHER IS NOT SO BAD AND MY BLADE DOES NOT LOOK LIKE OR GO LIKE A GOLDWING. THE MOD WAS NOT EASY I HAD TO MODIFY THE FAIRING BRACKET AND ELONGATE THE HOLES IN THE FAIRING. I HAD TO TAKE OUT THE FIXING STUDS OUT OF THE GIXER MIRRORS THESE ARE LOCTITED IN ONE SNAPPED. THEN HAD TO DRILL OUT AND RE-TAP. THEN I SPLIT THE MIRROR BODY FROM THE STEM BY THE 2 BOLTS THE M6 BOLT WAS THEN REFITTED USING A TAPERED TUBULAR SPACER. YOU ARE THEN LEFT WITH A SMALL GAP TO FILL I USED A FLEXIBLE FILLER TO COPE WITH THE VIBRATIONS THEN MASKED OFF THE MIRROR AND SPRAYED THE FILLER. THE GIXER FAIRING HAS A GREATER UPSWEPT ANGLE COMPAIRED TO THE BLADE SO IF YOU DON"T DO THIS MOD THEY WILL DROOP DOWN. WHERE I LIVE IN THE U.K THEY GET A LOT OF ATTENTION AT BIKE MEETS. AND NO ONE HAS SAID THEY DO NOT LIKE THEM. THEY WHERE A BITCH TO DO BUT IF YOU CAN"T BUY PARTS TO YOUR LIKING OFF THE SHELF THEN THIS IS THE ONLY WAY TO GO.
shakey
03-17-2011 02:46 AM
invader_zoom
10-10-2007 11:35 AM
