Intergrated taillight and hotbodies flushmounts problem
I am thinking of getting a clear alternatives intergrated taillight and the hotbodies front signals. These will both be LED's. Will i run into a fast blinking problem for ALL front/rear lights if i install the the resisters that come with the clear alternatives tailight? I don't care how fast they will blink but i am hearing that they might just all fliker. These will be on a 07 1000rr.
RE: Intergrated taillight and hotbodies flushmounts problem
I have both l.e.d. taillight and l.e.d. front turn signals and they blink fast. Both pieces included the proper resistors to simulate regular bulbs but I left them out on purpose. The higher flash rate gives the turn signal more attention.
my two cents.
my two cents.
I have this exact setup on my '05 & I really like it... I was concerned at first about the fast flashing signals, but it actually looks really good...The HB's are really bright, so that helps too...I seriously doubt you'd be disappointed with this setup...
i'm having trouble wiring the hotbodies front turn signal. when i hook them up the rear taillight turns orange and the brake light does not work when pressed. the turn signals stay lite on the display. does anybody know what the problem is. and also if the front signals are running lights or they stay off. or only used for signaling?
I run this exact setup on my 06 and It blinked to fast for my taste, so I bought a new blinker relay for $20.00 from cycle gear and now Im back at stock. Those hotbodies look good but you really cant see them from the front so keep an eye out and use hand/arm when you need some one to see you!
CBR55- Do You have your tail light and blinker wires crosed on your tail maby? as far as the hotbodies flush mounts bieng running lights also, I just capped my running light wire and just hooked up the blinker wire. That might also be your problem with your light staying on, did you hook up the running light and blinker light wires from your bike to the flushmounts? just put a piece of shrink tubing on the running light wire and forget about it!
