Intake Flapper Removal
Just did the mod yesterday and it made the exhaust a little throater. I found thing I noticed most was the engine noise was louder in the front end. Has anybody had any problems from doing this mod? I think I'll ride a week or two to see if I like it.
Jeff
Jeff
ORIGINAL: Weatherman
Jeff
Jeff
Otherwise it gives a little pick up in mid-range.Cheers
It does free up more air into your bike so wouldn't that make your bike run lean? If you are going to do this mod only.... I do not recommend it. Put a slip-on, PCIII and air filter then you change how the bike performs. Now you can consider the flapper. I might be wrong though. I changed the muffler and added the PCIII before doing the flapper so I could not tell you what the difference is with just the flapper mod.
