How much does rear tire size matter?
Old Jun 17, 2020 | 01:40 PM
engineer40's Avatar
Default How much does rear tire size matter?
Hello all. I purchased a CBR1000RR last summer. The person gave me a new set of Michelin Pilot Power 3 tires for it. The front tire is the same size. The rear tire is different. Stock rear is 190/50 17. New Michelin rear is 190/55 17.
Is that enough of a size different to notice a performance difference in acceleration? I'm really a 0-120mph type of guy. I never go out trying to top my bike out.
Are there any benefits of a taller rear tire on a sport bike that I have not considered?
I usually wouldn't fret about a small difference in tire size. But last summer when I put new tires on my Raptor ATV, the rears were 1 inch taller and I regret it. But these CBR tires are not measured in inches and I'm not sure the real difference in ratio between a 50 and 55.
Thanks for any opinions! Much appreciated.
Old Jun 17, 2020 | 02:01 PM
74demon's Avatar
It won't make it faster, but it will make it handle different with the rear set a little higher, probably for the better.
The aspect ratio is a percentage of the width. The height is 50% (or 55%) of the width. That 55 is 5% of the width taller than the 50, which is not much but enough to feel a difference.
Old Jun 17, 2020 | 02:40 PM
engineer40's Avatar
Thank you. I did not think it would be faster. I assumed it will accelerate slightly slower. Which is what happened with my Raptor ATV (unfortunately). Thanks.
Old Jun 20, 2020 | 09:28 AM
Doc Samson's Avatar
It will be slower but, unless you are at the strip, I bet you won't be able to tell. Better turn-in, otoh, I think you'll notice the first time you get into some turns. Oh, and your speedo will be off a bit as well...
Old Jun 22, 2020 | 07:30 PM
boredandstroked's Avatar
The only difference will be the bike leans over easier and is better to ride all around. They really should just stop making 190/50's.
Old Jun 23, 2020 | 11:00 AM
engineer40's Avatar
Thanks everyone for the replies!
I've had a rear pit bull stand for a while. Just got my front stand delivered a couple days ago. I'll be taking the wheels and new tires in soon to get changed over.
I've researched a bit on if installing the new tires could be a DIY project. But for the most part, people say it's not worth the headache.
Old Jun 23, 2020 | 11:20 AM
Doc Samson's Avatar
Having changed my own the last 4 sets, I would have agreed with that assessment... until the last set I changed a few weeks back - https://cbrforum.com/forum/general-t...i-know-160323/
Of course, if you can find a shop that doesn't charge $50 per tire, it still might be worth it to have someone do it...
Old Jun 23, 2020 | 12:17 PM
chris0986's Avatar
so....the difference in tire circumference....
If I'm right 17"*2.54= 43.18cm (sory, I have a problem with Disney units(imperial))
a 190 tire is supposed to be 190mm wide (I'm not the only one having trouble with Disney units) of which 50% = 95mm height vs 55% 104,5mm height.
Ad these to the diameter of the wheel: 43.18+9.5+9.5 =62.18cm diameter
vs 43.18+104.5+104.5= 64.08cm
circumference wit 50 tire is 62.18*3.14 = 195.25cm (76,87")
with 55 tire is 64.08*3.14=201.21cm (79,21")
difference is around 3% in diameter (around 9km/h at 300km/h)
I honestly expected more difference.
Moustafa Maged
Jun 13, 2012 05:51 AM
900rrSTUD
Nov 23, 2008 03:32 AM
bluestanger66
Aug 27, 2008 08:13 PM
SoloRider
Jul 3, 2008 04:42 PM
1slowf4
Oct 8, 2007 02:13 AM
