How long to install slip on
I'm thinking about tinkering with my bike tonight and installing a slip on.
Does any one have input on how long you think it will take?
I haven't even started looking yet, but
I really want to hear the thing and ride it in the morn. I have to get up early,
so 10 o'clock may not be a good time to start.
Well,
I couldn't do it in an hour. I was on pace til I started screwing with the exhaust servo valve.
I didn't realize it had a cover, so I wasted quite of bit of time there trying to unscrew the cable.
Even after I realized that, I couldn't get a damn wrench on the top cable nut. Finally got it.
What's sending me to bed? I can't get the damn mid-pipe from D&D on the muffler. It's
painted black, so I guess I'm gonna have to go back at it after I have some more patience.
Need to tweak the mid-pipe to get it started or sand the paint off the muffler a few mm from the
ends.
Anyway - I'm going to bed. Thanks for motivating me to tear into my bike. Guess I'll take the truck
tomorrow. haha.
ends.
tomorrow. haha.
dam - no! I didn't know this! I just got home today and was gonna finish up tinkering with the thing tonight.
What do you mean I need to mark the servo valve? Can you explain a bit more or provide a link?
I didn't think they made bikes smart enough yet to sense this emisions stuff. Am I screwed?
I already removed it. Thanks for the warning! I'll search around the net, cause I figure most guys are out riding
if the weather is like it is here.
Anubis, by the way... I unscrewed just the cables to this point and removed the stock
exhaust. I'm getting ready to put the new exhaust on, but your question has me a bit
concerned. I wasn't totally clear on the design of the exhuast servo cables when
I started, so I just kept unscrewing the clamp bolt from the outside on the bottom
one. I expected it to eventually unseat the cable and I'd be halfway there (top one left).
After threading the thing out for an eternity, I realized there was a cover and unscrewed it.
Removed the cables from inside the pulley. I didn't actually tinker with the valve that pulls
or pushs the calbles.
Am I OK at this point? I want to install the new exhaust and get riding and remove the actual
servo later. Will I be able to remove it later based on what I described or did I screw up the
factory settings and won't be able to "mark" it like you described?
Thanks!
Thanks!
Done. Took it for a ride afterwards.
No light.
Only went a couple miles, tired and a few beers in me to deal with the damn
fitment of the mid pipe to can. It took me a couple hours to tweak the flanges
and sand the paint off the male part of can's pipes. Pain in the ****!
In the end, the pipe sounds awesome. Didn't want to wake all my neighbors up so I went easy.
Can't wait til tomorrow. I'll let it rip then.
Can anyone point me in the right direction with regards to the exhuast servo? Do I need to
do something else based on my previous posts.
Any help would be appreciated.
No light.
J-
The only real pain was getting the muffler to slide into the mid pipe.
Disconnecting the servo cable delay was cause I didn't realize I should
remove the cover to get the cables off. Just remove the cover and
back the cable nuts off a bit.
Not sure what the concern is with the servo, but I rode it about 60 miles
today and no light or problems.
My advice if you have trouble with the midpipe to muffler fitment is to take
some time to sand the first 10mm or so of engagement on the muffler pipes
where they enter the midpipe. If yours aren't painted maybe you'll have no problems.
I sanded the paint (or black oxide - whatever it is) off and spent some time
tweaking open the pipes on the muffler side of the mid-pipe. Once I did this
it slid in a whole lot better. The fit of the midpipe onto the exhaust header
was fine. I'd try sanding first to see if you can avoid having to tweak the opening
of the midpipe. Will make it easier to put the clamps on if you don't have to open it up.
I used a flathead to spread out the opening. Not sure if sanding would have been enough.
Good luck. It's worth it in the end. The pipe sounds great.
