hmmmm!!
Old Nov 28, 2006 | 12:41 PM
GEARHEAD69's Avatar
Default hmmmm!!
I found it impressive after my trip to the dyno yesterday how strong the new bikes are from the factory!! I mean even with the quiet pipes that we think restriction less hp, restricted intakes, enviro crap .... after modding with good parts its hard to beat what they're puttin out.. with out some serious internal mods !!
[sm=hail.gif]
Just tippin my hat to the Gents @ Honda for building one bada$$ BIKE!!!!!
Old Nov 28, 2006 | 06:49 PM
raredogg's Avatar
Default RE: hmmmm!!
ID say they are silent from the factory, thats why i aint doing any mods!
Old Nov 28, 2006 | 09:52 PM
baxsom's Avatar
Default RE: hmmmm!!
so how much
dyno sheet?
come on you cant put up a post like that without even giving us a number
Old Nov 29, 2006 | 11:02 AM
GEARHEAD69's Avatar
Default RE: hmmmm!!
I posted the numbers in another post but here they are...
run conditions 79 degrees 40% humidity
148.77 rwhp
71.8 ft lbs
The Yammie I went with 05 r1 similar mods
147
71
Old Nov 29, 2006 | 07:05 PM
baxsom's Avatar
Default RE: hmmmm!!
that right at what my arata put down
(149) with a downloaded map
Old Nov 30, 2006 | 01:02 AM
GEARHEAD69's Avatar
Default RE: hmmmm!!
Yeah my buddie runnin the dyno works on Zukes for the most part, and that 1kRR got a little nodd which from them Zukes boys is sayin alot !! Our mods are relatively close i think. your useing the BMCs and Arata and didn't you put a new intake in your bike?? I've got the K&Ns, Yosh slip, flapper mod, PCIII with little map tweakin and was told might smooth another pony or two out with a little finess !!
Honda power and reliability !! [sm=happybounce.gif]
Old Nov 30, 2006 | 08:04 AM
baxsom's Avatar
Default RE: hmmmm!!
yeah i have a new intake but havent had it dynod since it was put on
my af was way off with the downloaded map like 13.96 so once i get a custom map and get closer to 13.1 that should bring the ponies up a little
also what tire pressure did you run your rear tire at
i was reading that if you lower the tire pressure it will put down less hp
dont know if there is any truth to that but i do know my rear tire pressure is almost 14lbs lower than the 42psi max
Old Nov 30, 2006 | 10:46 AM
GEARHEAD69's Avatar
Default RE: hmmmm!!
I normally run my rear at about 38psi frt 36 they also say tread wear can change power #s as will dirty chain !!
So Baxsom i read a thread from you awhile back about you makin some race skins for your ride !! You done streetin that thing??? Iknow you've been modden the heck outta that thing !!
So I see you did the steel braided lines! How'd it go for you on the install and how do you like em???? I was thinkin that to be my next mod!!
Old Nov 30, 2006 | 06:30 PM
baxsom's Avatar
Default RE: hmmmm!!
ORIGINAL: GEARHEAD69
yep race skins all ready to go
still gonna street ride though
i just wanted the skins so i didnt totally destroy the bike if i lay it down in a turn
the steel lines were an easy install
the only real trick to remember is which line goes on which side for the front
they feel great
lots more feedback and fade isnt near as bad when the fluid gets hot
next mod
brembo master cylinder
and maybe 954 wave rotors
they are 330mm compared to the 06 320
[IMG]local://upfiles/8895/46ABD0927BEA42588E95B1C4DD7B78A0.jpg[/IMG]
flyboy1011
Sep 29, 2009 05:26 PM
slug bitch
Feb 3, 2009 03:29 PM
ChrisMcD
Jun 29, 2007 04:49 PM
Hemmings1000RR
Aug 30, 2005 12:53 AM
