Exhaust Valve... Needed or Not???
Hey all. Just got my D&D Exhaust slip on today however it didn't come with an exhaust valve. When I called Super Bike Supply they said it was an unneccessary part and to just go ahead and remove the cables. Is this true or where they blowing smoke and I should be making some more calls to get a tube with the valve. I'm not in CA so the emissions isn't an issue.
J-
J-
RE: Exhaust Valve... Needed or Not???
You do not need the exhaust valve. It's for noise emissions.
Anything Superbike Supply tells you is usually true.
The servo will reset itself the first time you turn on the key, so you don't need to worry about marking it or having it in the same spot etc.
With the stock ECU, you cann't remove/unplug the servo without setting of a MIL error.
With something like the HRC/Kyle Ecu, you can remove the unit completly without errors. Saves exactly 1.00lbs.
