EGCV Servomotor
Old Jul 24, 2007 | 11:20 PM
RaistlinCG's Avatar
Default EGCV Servomotor
Okay, in the process of removing the stock exhaust to install a new canister the instructions call for removing the cables coming from the valve attached to the exhaust and removing them from the servo located under the key latch on the left side of the bike.
My questions are these:
1. What does that valve control? It seems ridiculous and unimportant, but it must serve some purpose.
2. Do I need to disconnect the servomotor 6p (natural) connector as well? Will the bike detect some type of malfunction if the power to that isn't disconnected but the cables are?
I appreciate it.
Old Jul 25, 2007 | 12:44 AM
RaistlinCG's Avatar
Default RE: EGCV Servomotor
I think I have answered the first question for myself. I saw the flap inside the pipe, just before the stock canister. But that still leaves question #2 open, do I need to unplug the power to the servo?
Old Jul 25, 2007 | 05:36 AM
baxsom's Avatar
you must leave the servo motor plugged in or the ecu wil think that there is a problem and put the bike in limp mode
just unhook the cables from the motor and all will be fine
honda says that the valve is there for low end torque
in reality it is a EPA noise reduction thing
just like the intake flapper
Old May 15, 2011 | 01:02 AM
toofass4udoo's Avatar
Default FI code 3 5 cbr 954
Cool,
I'm about to do this on my bike (CBR 954 w full exhaust). I am getting a 3 5 error code (EGCV AND AIR INTAKE VALVE SERVO MOTOR). Just to be 100% clear on this, I am going to unhook all the cables to the servo motor?
- as shown @
2002 Honda CBR954RR Parts, 2002 Honda CBR954RR OEM Parts - BikeBandit.com
It shows 3 cables - an air valve cable, and exhaust valves cable A & B. I'm going to unhook all of them?
If thats correct do i need to plug these cables? or just leave them open. Any info greatly appreciated. Thanks
Old May 15, 2011 | 07:49 AM
9-5=4rr's Avatar
Yea ... you unhook both cables going to the exhaust valve and the one going to the flap in the airbox ... then you can remove the flap itself in the airbox (really simple job) and your new exhaust system will take care of the exhaust valve ...
You can completely remove the cables from the servo itself or just wrap them up and tuck them away and just leave the servo connected to the bike so the computer stays straight ... any problems let us know ...
Old May 16, 2011 | 11:46 PM
Default servo cables removed still get error code
Ok. So I removed the all three cables and removed the flapper. I then reset the ECM diagnostics, but I'm still getting a 3 5 error code . What am I missing? I've seen on a couple different posts people saying "set the servo motor to the correct position" or "return servo motor to its original position". Any ideas on what that may mean or if it even matters? I mean it's a DC motor right? Or any way to trick the ecm into thinking that all is well with the servo motor? Any ideas greatly appreciated. Thanks
Old May 17, 2011 | 12:12 AM
I'm messing with the servo motor -
1) I don't see any adjustments to make. The pulley seems like its fixed in one position
2) When should this servo motor move? I turned the engine on, revved the engine and the pulley stayed in the same position. I imagine it should be moving?
Old Dec 15, 2011 | 04:20 PM
giova2k11's Avatar
Hi, sorry to bump an old thread; does anyone have a datasheet of this servomotor or knows where to find one? I need that for our Formula SAE project, we use a CBR600F4 engine and we want to fit the exhaust with a valve like the one on the CBR1000RR to improve low and mid end torque (the logic of opening of the valve would be different from the stock one to achieve this) and we need to choose a motor to move it, so it would be helpful to know some data on the stock one.
It may be enough for me if someone could check if there is any brand or code on it besides the Honda part number which should be 31420-MFJ-A41 or something like that, the one I posted is for the 2009 model.
Thanks in advance!
Bigpopper
Aug 7, 2011 10:37 PM
Nealio240z
May 27, 2008 09:16 PM
2WheelinF3
May 12, 2008 07:32 PM
ejase
Dec 30, 2006 01:31 AM
