Cutting fairings!!
Old Nov 7, 2008 | 03:08 PM
Ridered1000rr's Avatar
Default Cutting fairings!!
Does anyone know a good tool to use to cut fairs so it looks good and not half assed?
Thanks for help
Old Nov 7, 2008 | 04:43 PM
Pamw's Avatar
Default RE: Cutting fairings!!
a dremel with a course burr......better would be a pneumatic die grinder with a burr...it has a wee bit more power than the dremel and doesn't get hot so quickly....and then the edges and be smoothed out with 320 or 400 wet or dry paper
Old Nov 7, 2008 | 05:23 PM
TBagr's Avatar
all of those work well but when it comes to this i just take it to a dealer and pay them. y? simple...if it gets messed up then they replace the fairing free of charge. cost you a couple of bucks but it is worth the peace of mind to me...
Old Nov 9, 2008 | 04:11 PM
thanks guys for the help. Tbagr i hear where your coming from, but i really dont like anyone else working on my bike.
Old Nov 11, 2008 | 02:12 AM
Ara's Avatar
Ara
I bought Woodcraft frame sliders that require cutting. I'll check tomorrow and give you the name of the cutting tool I used. It turned out just fine. Remember the old saying, measure twice and cut once.
Old Nov 11, 2008 | 07:06 AM
Pamw's Avatar
name of the tool?
saw.....rotary cutter...knife......hole saw?
[sm=nerd.gif]
Old Nov 11, 2008 | 07:33 AM
trainedkilla's Avatar
I use a stencil on the plastic. I cover the area with blue painters tape, draw the circle where I want the hole to be, drill a small hole dead center with a dremel and then use the dremel cutting tool (round) and work my way around. I then sand the edges with the dremel sander.
Old Nov 12, 2008 | 12:48 AM
Ara's Avatar
Ara
It's a "Rigid" brandHole Saw w/pilot.
The Woodcraft sliders come with instructions telling you what size to buy.
And you will need a Dremel with the sanding drum to clean up the hole.
cbrdevil32
Mar 9, 2013 09:47 PM
Mr.Green
Oct 9, 2010 03:42 PM
bcouncill
Dec 7, 2008 08:02 AM
dannutz
Mar 19, 2008 01:00 PM
Heretic
Feb 2, 2007 03:59 PM
