Changing rear tyre only?
Hi there,
As many of you, my '06 RR came with Pirellis Diablo Corsas, but these are discontinued.
My front tyre is still in excellent shape but I need to change the rear tyre.
Would it be a problem to change it for one of the new Pirelliseven if it won't be the samemodel as the front, or should I change both in order to have the same compound?
Pat
Pat
ORIGINAL: Onarom
A similar question was asked before.
But thanks for the feedback, gents.
I will order a Corsa III. Worst case scenario, should I feel it does not work good enough with the front Diablo Corsa, I will order a new front too.
Pat : )
I have a corsa on the front and a corsa III on the rear...........it's fine. If you stay in the same brand you are generally ok. Not only are these in the same brand, they are essentially the same model.
