chain lubrication question
#31
RE: chain lubrication question
ORIGINAL: tomc1965
SD2007
How often do you lube your chain with WD40? What type of weather do you ride in?
SD2007
As far as WD-40 removing grease from behind the O-rings, I'd like to know where this originated and under what circumstances it happened. WD-40 seems to be almost universally accepted as a chain cleaner, so I'm not sure what the story is. If WD-40 removes grease from behind the O-rings, I don't think my chain would have gone 20,000 miles with such little wear.
I wasn't able to find anything about motorcycle chains on the WD-40 web site. For bicycle chains they say it cleans and lubricates, for whatever that's worth. I use a chain lube on my bicycle sincethat's the only thing that lubricates the link pins.
#32
^^^^ NO NO NO NO!! WD-40 is a solvent and eats way at the o-rings! (it ruined my chain and I hate to recently replace it.)
I would get some Simple Green. You can use it on anything, and is a must for any garage/shop. Plus it's safe for the environment and is non-toxic.
Just take a tire scrubber, spray Simple Green onto the chain and scrub off all the grime. Rinse off the chain really good and take the bike for a short ride to warm up the chain. When you get back, spray on some high-quality chain wax or apply gear oil. I personally use Chain-wax. (Belray I believe). Great stuff, doesn't fling off and the chain stays relatively clean.
Make sure you clean and wax your chain every 500 miles if you ride it a lot, or every couple of weeks if you ride on occasion. If a chain fails on you, it's not a fun thing. So it's best to keep this extremely well maintained. You can always tell if someone takes care of their bike or not. If their chain is completely black, covered in a thick layer of grime......you know the rest of the bike has been neglected as well.
Oh, and remember.........
NEVER USE WD-40! No offense to anyone who suggested it, I use to use it before it ruined my chain, now I know, and now you know.
#34
I had a scottoiler fitted.
I never have to clean or lube the chain, I just keep the scottoiler topped up with oil.
And I have ridden the bike for 4000 miles without any chain adjustment, and its still fine and doesnt need any.
It keeps the chain in very good condition and really prolongs the life of it, and save a lot of time and hassle for mecleaning and lubing the chain.
