Blade Engine Diag/Noise
Old Nov 22, 2024 | 06:15 PM
Saishi_Ringo's Avatar
Default Blade Engine Diag/Noise
(Reposting this here cause I think I put it in the wrong place) I posted in here a while back, should be able to see the original thread on my profile, but to get to the point, I was curious if I could fix my issue by just swapping out the cylinders+head along with the piston rings. Quick flashback, the blade started making an odd noise and the oil light popped up. Oil went out somewhere it wasn’t supposed to be and it got pretty low oil-wise before I was able to do anything about it. I had a buddy of mine drain the oil recently since I had never gotten to it myself (whoever did the oil last before me overtightened it way too much). But this is what he found in the oil. The big chunk in the center is apparently plastic, everything else is metal shavings. I’d like to know what y’all think it could possibly be from and if the motor itself is salvageable without doing a full bottom end rebuild. I also reattached the vid including the knock/ticking noise it was making. Once again thanks for all the help in advance.
Attached Thumbnails Blade Engine Diag/Noise-resized_20241116_161959_1731795649615.jpeg
File Type: mov
Saishi_Ringo
Nov 25, 2024 11:52 PM
mlivelo
Aug 27, 2024 06:18 AM
Pmmaxwell
Aug 19, 2022 07:47 PM
billybath4732002
Jun 3, 2011 08:24 AM
liljoec
Apr 3, 2006 03:54 AM
