Better brake pads
RE: Better brake pads
Yeah I seen the Ebc pads, but haven't heard any reviews..
Ferodo Brake Pads?
Gold?
Galfer?
Has anyone tried one of these?
I have HEL SS lines, and some Dot 5 silicone brake fluid.. I just rebleed the system and tried this brake fluid... Some guy on the GSX'r site is using it and sad it holds up better than the average breake fluid, but if this doesn't work; I'm gonna try some motul.
Ferodo Brake Pads?
Gold?
Galfer?
ORIGINAL: Nevaeh Speed
Ferodo Brake Pads?
Gold?
Galfer?
Ferodo Brake Pads?
Gold?
Galfer?
I use my rear a fair amount whilst trail braking into lower gear corners to help set up the line in quick successive R/L/R esses; I also use the rear to tighten up the entry/exit when negotiating a tight corner. I really like the feel of the rear... very progressive; doesn't want to lock up the rear like the OEM did. Yet it scubs speed off much better than the OEM.
Remember though, that brake pad compounds are a VERY subjective opinion/sqauble. Much like tires or oil (sorry, I know this last one is treading into the abyss), so take eveything anyone says here with a grain of salt (including me). I've personally had great experiences w/ EBC, SBS, and Carbone Lorraine, too!
Cheers
The motul oil is good. Do not use silicone based brake fluid, it is slightly compressible(gives you a spongy lever!) and very much out of date.The Military use it for very different reasons, such so shocking abuse of equipment! (no servicing,wet climate etc). Do a google search on DOT and the results will surprise you.
