05 1000rr header gasket problem
Old Feb 25, 2012 | 05:48 PM
FrankTheTank707's Avatar
Default 05 1000rr header gasket problem
i ordered the header gasket from honda and just got them in today, my problem is that the brass crush gasket is round and the header pipes are oval. did they send me the wrong part or am i missing something
Old Feb 25, 2012 | 07:25 PM
MadHattr059's Avatar
Can you post a pic? I'm not following you. Are you saying the cylinders are oval? The headers go on to the front of the cylinder head at the exhaust ports, not between the lower-end and the cylinder-head which is where a head gasket goes.
Ern
Old Feb 25, 2012 | 10:04 PM
justasquid's Avatar
The header gasket should be oval. They do sometimes discontinue parts and supersede them with others, but I don't see how a round crush gasket will work. If its a genuine Honda part, there should be a number on the package. Go online and google search for a Honda parts fiche and cross reference the numbers.
Also, depending on what your doing, they are reusable. if your just removing the header and putting it back on, you can re use the copper gaskets. If your changing headers, then new ones will be needed.
Old Feb 26, 2012 | 05:58 AM
they sent the wrong parts, thanks for the replies. i ordered them from another site and verified that they were the right parts before i ordered this time. still not sure how they got the part numbers mixed up, but they will no longer be getting my business
Old Feb 26, 2012 | 07:06 AM
Thanks, squid! I was hoping someone with experience would pipe-in. As mentioned in other posts, the bottom end is not an area I am really really familiar with (missed saying as much, in this thread, "oops!"). I only commented to try to prompt for better info and to assure frank that someone was listening. ;-)
Ern
Old Feb 26, 2012 | 10:41 AM
justasquid's Avatar
No problem. I see that you are an extremely helpful member here and it doesn't go unnoticed. And going along with what you said, it never hurts to get a thread bumped for the reasons you mentioned. No one here is an expert on everything. But this forum with so many members that have experience in different areas combine to make a very knowledgable community. And you are a big part of that. So thanks for being an active member.
Old Feb 26, 2012 | 10:46 AM
justasquid's Avatar
Glad you got it figured out. Mistakes happen all the time. I generally try to give the benifit of the doubt when ordering and things are wrong. I look more at how they handle their mistakes. If they take extra care of you to get you the correct part, then its usually ok with me. Of course, if they make a lot of mistakes, I go elsewhere. But hopefully you found a new reliable place to order from.
Also, make sure to check out the rest of the forum. There are a lot of good members here. Depending on where you live, you could find new friends to ride with as well.
Old Feb 26, 2012 | 04:56 PM
thanks alot you guys have been very helpfull. you will be seeing alot more of me on here with my new toy!!
DBEAU
Mar 19, 2011 08:27 AM
ianfrombrum
Dec 1, 2009 09:49 AM
neel2008
Aug 31, 2009 01:57 PM
cbr929guy
Aug 21, 2009 08:39 PM
RYDINRED929
Feb 23, 2008 05:00 PM
