Yet another Jetting question.
Old Apr 8, 2006 | 12:13 AM
Trips's Avatar
Default Yet another Jetting question.
I have the Yoshi Ignition Advancer, K & N Filer & V & H 4-2-1. Now its time to rejet.
There are a few brands of Jet kit on the market. Is there any difference between the brands?
Also over here in Australia the Jet kits are bloody expensive. Works out to about $145 US! Do I have to buy a "kit" or can I save some $$$ and just the jets seperatly and shim the existing needles?
Old Apr 8, 2006 | 01:52 AM
CBR1988's Avatar
Senior Member & Lord of the Odometer (300,000 Mles) & Counting
Default RE: Yet another Jetting question.
Hey:
Thats what I did on my daily driver, 124 mains and 2 shim washers under the needle, if you buy a kit the factory brand kits
are good, but they all pretty much the same dynojet, k&n, and yosh.
I spent $25.00 total on the jets and washer/shims including postage, but I am cheap, it works and runs fine, but I just drive 80 miles a day
to and from work in nice wx 5x a week, so its all good.
Old Apr 8, 2006 | 03:11 PM
R1000's Avatar
I bought Keihin #125 jets here in Sweden and they costed 100 SEK which is about 15 dollars for all four.
Old Apr 8, 2006 | 06:05 PM
Trips's Avatar
How much did you shim the needles?
Old Apr 8, 2006 | 07:34 PM
R1000's Avatar
My bike had adjustable Dyno Jet needles already when I bought it. I raised the needles two steps which I remeber that gave about +3 millimeter lift from the nominal middle grove position. The bike pulled much better in mid range after that, still with stock #122 main jets and stock downpipes but dual aftermarket mufflers. I will go up to #125 main jets when changing the complete exhaust system to a 4-2-1 downpipe and single free flowing muffler. I'll see where the needles need to be placed after sorting out main jets for full power.
Old Apr 8, 2006 | 09:26 PM
dad's Avatar
dad
My bike is stock throughout. Even stock, raising the needles between .015" to .020" will clean up the middle nicely. There was always a little bit of a stumble when accellerating, somewhere around 4500 or so if my memory is correct. I raised the needles .017" by using a #4 SS washer that was .037" thick, replacing the stock washers that were .020". Those might be weird US designations but it's about a 1/8" screw that they fit.
On at least the '90 and '91 models, US 48 states, not sure about California model, the carbs came with a .020" washer on the needles. I visited the hardware store with my calipers and found and then matched a set of washers (the thickness varied all over the place) as described above but if that hadn't worked out, I would have just ordered another set of washers from Honda, the .020" ones, and added them. That was done around 25,000 miles and I'm at 122,000 now. Always ran well and took that slight flat spot out perfectly. Going more than that with stock pipes would have been too much.
newnut
Jul 15, 2010 10:03 PM
utter05
Mar 2, 2009 06:44 PM
jagdiver
Jan 8, 2009 05:58 PM
Yellowjacket900
Jul 4, 2008 07:54 PM
camoweasel
Jul 24, 2007 05:53 PM
