well it's still a work in process
Old Sep 5, 2006 | 09:35 PM
old1000's Avatar
Default well it's still a work in process
i changed a couple big thing so i figure i would post pics
*** end
left side
right side
sorry about the pics it was dark and i suck at taken pictures
Old Sep 7, 2006 | 10:49 PM
old1000's Avatar
Default RE: well it's still a work in process
you gonna tell me no one has any opions on it? i need advice in what direction to go in next
Old Sep 7, 2006 | 11:32 PM
hurricane1000's Avatar
very neat idea! i thought about putting a different tail scetion on my hurricane. from my research the early 900rr's had similar front mount for the seat, so that is the way i was leaning... what bike did yours come from? did you have to change the subframe to mount that tail?
you have what appears to be a nice line from the side panel to the lowest part of the tail, but i think you need to put something (not sure what) between the two. i have an idea or 2, but i would really need some better pictures of the area between the 2 body parts to maybe come up with something a little more concrete.
so post up some close ups, and lets see what ideas come from the members here...
BTW.... get that skinny tire changed...
Old Sep 10, 2006 | 12:52 PM
crucialfate's Avatar
old, very nice bik man!!! very nice indeed. i just painted mine with 2 racing stripes down the middle. well, my tail section is lose (due to a broken bracket) so the lines are somewhat off. so i had been toyin with the idea of putting a different tail on and now seeing yours, i think it would be a good idea. i basically have the same ?'s as 1000
Old Sep 11, 2006 | 02:48 AM
peterk's Avatar
excellent work, you are a talented dude! i pulled my rear end apart but it all looked to hard so put it back together, though did put a wider wheel on, have to agree with Hurricane, its a good look. is that the rear off another bike of did you do the mods from scratch? can you post some details on how you did this, am very interested. thanks
ps. there is a post in here somewhere by gwilson i think it is, he has done the single sided swingarm and tail off another honda, nice job, it must be nice to be talented!!!
Old Sep 11, 2006 | 02:53 AM
peterk's Avatar
g'day old, just spotted the correct name when i finished last post, grwilson6, i hope he doesn't mind me mentioning him, go to his gallery, worth a look...
Old Sep 11, 2006 | 10:49 AM
come on man.... you ask for responces, we give them, and you dont reply back....
Old Sep 11, 2006 | 07:40 PM
old1000's Avatar
sorry bro my computer sucks. anyways the rear end is off a 98 tl 1000r and mounting wasn't wicked hard! ummm i had to move all the elctronic stuff to the inside of the rear frame, i also cut an inch or two off it. and yes i defn need the wheel and i'm worrking on it. as for those side panels, the stock ones wouldn't flow at all so i cut them up and need some ideas to do a one off peice. so any help on make a whole panel would e apreciated. sorry it took so long.
Old Sep 11, 2006 | 08:46 PM
post some close up pics of the area from the side, top, rear angle, and front (basically all around) for both sides. i have an idea for some covers for you, just want to think it through before i go on and on and on and on.... you get the picture...
it looks like you may have some fabbing skills, so my idea should be easy for you to work with... do you have a heat gun?
as for the rear wheel, i dont believe that you have to stay with the cbr1000f rim. if i were a betting man (judging from last sunday, not a very good one at least), i would look at the 900RR, 1100XX, superhawk, or any other liter class honda bike. IIRC, they all use the same sprocket side spacer (get the part number from bike bandit, and compare with the other models). if this is true then they have the same engine sprocket offset, so the only difference is the brake side, and you already need to make/get a spacer for that to work anyways.
honda used alot of the same parts on different bikes, that is how i was able to put the 99 1100xx front end on my 88, they use the same head bearings, just a different length steering stem.
Old Sep 18, 2006 | 07:23 PM
collector's Avatar
nice bike. have you thought of making a mold first and see how that fits in, at least then you might be able to see where you want to go with this. good luck, and look forward to further progression.
yunebug
May 26, 2011 06:19 AM
fiveoh
Sep 21, 2009 08:10 PM
Browntowns20s
Apr 19, 2009 09:29 AM
r_mutt
TRG Coating
Dec 1, 2006 12:44 AM
cbr4ever
Nov 21, 2005 04:23 PM
