Vfr bars came..i think i fu...made a mistake!
Old 07-16-2009, 05:05 PM
davethepom's Avatar
Thanks for posting the pics malbojah. Those bars don't look like the ones I just got from a '92 vfr so what you're saying, karlo, makes sense to me. I'll take one of mine off and take a pic with both to compare. I wish I wasn't stuck at work right now and could investigate right now. Those bars look really good on your cbr and that's what I'd hoped to get.
Old 07-16-2009, 05:50 PM
hawkwind's Avatar
Hey Malbojah , whats that you've got on the centre bolt of the triple tree , with the round black **** ? It looks like a windy-uppy thingy wotsit!
Old 07-16-2009, 07:46 PM
Sprock's Avatar
Ram Ball Mount for a Tom Tom or Garmin GPS by the looks of it
Old 07-17-2009, 08:47 PM
malbojah's Avatar
Originally Posted by karlo
So what do they measure between these 2 points?
I think there are early and later bars the above are later ones after 94.
I want to say it's 1 3/4" or 2". I won't be able to check till Tuesday (working straight through)
Old 07-17-2009, 08:58 PM
kilgoretrout's Avatar
Administrator - Retired
Ha ha.. I was wondering the same thing. I just figured you could crank it really fast while riding and you would go faster.
Old 07-19-2009, 11:00 PM
davethepom's Avatar
Default Pictures at last!
After some patient computer help from Steve (and some welcome pi55 taking, thanks mate) here are some pics of '92 vfr750 bars compared to my '94 cbrf. Mine are the ones that are more shiny at the fork end. They would go on, but would have to be modified, and I don't think they'd look as good. They're 3/4 " ish higher and set further back on the clamp. Also they're higher still at the bar ends so hands would be flatter. I don't really want to change angles, only height and therefore reach (due to fork angle). The wrecker will take them back, so I've only blown the freight and I can live with that. If later model vfr bars were available they'd be the go I think, but I think it'll be the Genmars for me. Anybody know if they have the locating lug on the bottom of them and a corresponding hole in the top for the lug on the standard bars?
Attached Thumbnails Vfr bars came..i think i fu...made a mistake!-vfr-750-bar-comparison-001.jpg   Vfr bars came..i think i fu...made a mistake!-vfr-750-bar-comparison-003.jpg   Vfr bars came..i think i fu...made a mistake!-vfr-750-bar-comparison-004.jpg   Vfr bars came..i think i fu...made a mistake!-vfr-750-bar-comparison-005.jpg
Last edited by CBRclassic; 07-19-2009 at 11:18 PM. Reason: Easier to see them all in on page :-)
Old 07-20-2009, 12:00 AM
pacojoseph's Avatar
FWIW, I don't think you'll like the Genmars, especially at $117 US shipped to the US, but to answer your question, the answer is yes, they do have the locating lugs.
Old 07-20-2009, 03:45 AM
karlo's Avatar
Old 07-20-2009, 12:05 PM
TimBucTwo's Avatar
I was responding to this thread.
https://cbrforum.com/forum/cbr-1000f-hurricane-38/dumb-computer-question-97505/
Originally Posted by davethepom
They'd have to be modified to fit and wouldn't look as good as my originals so I'll send them back and look into Genmars, first raising the clamps to try.
I have GenMar risers and I am not 100% happy with them. I like the rise but I still don’t like the way the bars angle back and down. If I grab the bar and touch my index finger with the tip of my thumb (making the ‘OK’ sign) and then clenching my other three fingers and resting my finger nails on the bar, that is where I would like to be. Two days ago I did a 376-mile ride. I did about 50 mile in the woods on some steep up and down dirt roads that were quite slippery. My hands are still sore on the three end fingers on each hand from the grip angles. Those VFR bars look interesting because of the fact that the bars are set back in the clamps. I can’t push mine forward (I tried yesterday) because they will hit the windscreen, where as the VFR ones may not. Also, if the ends were higher that would be a plus.
With the GenMar risers, you are rising the clamp and not getting the full clamping pressure and need to align the old tab to the hole in the riser, the raises has a hex bolt in the bottom that aligns with the slot that the old tab went into. This way the bars will not rotate when let’s say lifting the bike. You should have the full clamping pressure with the VFR bars and should be able to cut the tabs off and rotate the bars to where you want them.
If I were you, I would try to raise the bars before sending the VFR bars back just in case you change your mind.
Now you have me thinking about VFR bars. My old hands can’t take the pull back of what I have now.
Quick Reply: Vfr bars came..i think i fu...made a mistake!
