vacuum leak
Old 06-22-2007, 02:39 AM
grwilson6's Avatar
Default vacuum leak
hey guys i was reading through my new jet kit notes and it says something about if you rev the bike and it doesn't come back down to idle right away there could be a vacuum leak. my bike is doin this. has anyone else experienced this? is there a common spot to check first before i dive in? the motor does have over 50,000 on it but i was hopin it wouldn't need a major overhaul anytime soon. thanks for any help you guys can throw out there.
Old 06-22-2007, 03:03 AM
Trips's Avatar
Default RE: vacuum leak
How long does it take to come down?
The CBR by nature have a heavy flywheel and the revs dont drop that quick.
Old 06-22-2007, 03:47 AM
grwilson6's Avatar
it comes down after acceleration okay but before it gets to idle speed it hesitates for a bit so i don't think its just the weight of the flywheel
Old 06-22-2007, 04:25 AM
R1000's Avatar
Are all rubber caps for vacuumtests in place ?
Old 06-22-2007, 06:59 AM
How often does your throttle get stuck? Mine did not roll back all th way!!! did the same thing!!
Old 06-23-2007, 09:40 PM
grwilson6's Avatar
i dont think the throttle is sticking, it seems very quick to snap back into place. the rubber caps are all installed also. i wonder if the rubber intake boots the carbs attach too have gotten hard and crusty and are letting air past?
Old 06-23-2007, 09:58 PM
malbojah's Avatar
ORIGINAL: grwilson6
You could do a leak-by test: spray some WD-40 around the intake boots. If the revs increase, there's your leak.
Old 06-23-2007, 10:11 PM
Trips's Avatar
Are you sure you just haven't got the cables mis-adjusted.
Old 06-24-2007, 01:51 AM
To the OP, if the idle doesn't return to normal smooth idle quickly it's too rich. If it returns and then stumbles before resuming normal idle it's too lean. This only applies to the idle cuircit however. If the needles are bad or the jets are wrong that only effects off idle performance.
Old 06-24-2007, 08:29 PM
grwilson6's Avatar
yeah i've got the cables set up correctly, i'll have to try the wd 40 trick.
Quick Reply: vacuum leak
